Enables the OSPF module to send traps on various OSPF events.
| all | Sets RFC1850 ospfSetTrap to 0x1ffff. |
| trap-map | Specifies the ospfSetTrap as defined in RFC1850. |
| bit-map | Specifies the ospfSetTrap value in HEX (for example, 0x1ffff for all traps). |
The default is disabled.
This command enables the OSPF module to send traps on various OSPF events.
The following command sets ospfSetTrap for all traps:
enable snmp traps ospf all
This command was first available in ExtremeXOS 12.6.
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
